9.5.16 - 64bits
9.5.16 - 64bits
The new linux 64bits version should be a lot faster than the previous.
Hervé ADAM, TVPaint Team
Re: 9.5.16 - 64bits
Indeed, I was wondering if that was me dreaming, then this explains a lot!
Now the best smooth is as fast as medium/normal smooth, and the little lag of the cursor tool preview I had noticed is almost disappeared (at a point it's barely noticeable so it's not annoying anymore).
And I guess everything else will go faster then, I'll have to try it again more deeply to see it.
As always thank-you Hervé!
- d_rylander
Re: 9.5.16 - 64bits
Something goes wrong when installing.
First I just ran the deb and upgraded the old version (9.5.11). Installer said same version already is installed (9.5) so I choose reinstall.
Then when trying to run TVP i get the following:
Tried to uninstall and reinstall from fresh. Same error.
Ubuntu 8.10, 64bit.
david@dubbelbuntu:~$ tvp-animation-9-pro
tvp-animation-9-pro: /lib/libuuid.so.1: no version information available (required by tvp-animation-9-pro)
tvp-animation-9-pro: /lib/libc.so.6: version `GLIBC_2.11' not found (required by tvp-animation-9-pro)
Ubuntu 8.10, 64bit.
Re: 9.5.16 - 64bits
I guess it might be a library version problem on Glibc , maybe since you're on an "old" 8.10 system (here on a 10.04 it works fine).
