Sewie's Hairy Brushes
Sewie
Post by Sewie »
For those of you interested in custombrushes. I've made some textured brushes for painting in TVP.
They are quite simple; you can get different nuances by fiddling with the settings. Like opacity, etc.
(The picture below is pretty big)
Edit: I can't seem to upload the .tvpx file to the forum so here's a link.
Edit2: Herve Fixed it. (below)
Hervé
Re: Sewie's Hairy Brushes
Post by Hervé »
Sewie wrote: Edit: I can't seem to upload the .tvpx file to the forum
's Hairy Paint Brushes.zip
(763.19 KiB) Downloaded 478 times
Thank you Mike
Hervé ADAM, TVPaint Team
malcooning
Post by malcooning »
Cheers for sharing sewie.
meslin
Post by meslin »
Really, really awesome. I had a toolbar full of brushes like these but I can go ahead and delete mine now.
In smear mode, on a fast computer, these really shine. Makes me want to buy the 6D intuos pen so I can have more orientation control.
Thanks so much!!!
/David
Sewie
Post by Sewie »
You're welcome. You can set the angle of these brushes to 'direction'. Gives more or less the same result as when set to 'rotation' and used with a pen that's rotation sensitive.
But I believe I've done that for most of these brushes...
...on a fast computer, these really shine.
I've tried to optimize the brushes as much as I could, so I believe they should do well on normal or medium-fast processors as well.
ingie01
Post by ingie01 »
Thank you sooo much for the brushes.....all that work deserves at least a thank you!
chatbraque
Post by chatbraque »
… and an other one !!… for all that work, that works !
