FX: Add border..
CartoonMonkey
FX: Add border..
Post by CartoonMonkey »
Would it be possible to have FX: Add Border work on display mode? ( all layers ) ?
Re: FX: Add border..
maybe can you use the "Image Source FX" before the "Add Border FX" on an empty layer?
CartoonMonkey
Ah perfect! I hadn't actually ever used that effect before, thanks!
My characters have to be filled with a moving texture. Before, I filled the screen with blue around my character, had my looping animated texture on the bottom layer, and then merge all / key out the blue.
Does anyone know an easier way to drop fill an animated texture inside a shape?
C
CartoonMonkey wrote:Ah perfect! I hadn't actually ever used that effect before, thanks!
C
there must be at least 10 variations to do it.
and some of them might be a few steps shorter then yours...
also its probably better not to use keying as it tends to eat at the edges of your lines.
here is how i would do it: switch on the stencil for your blue mask layer (the S colomn in the layerpanel)
(oh and you can best create the mask on a seperate layer (using fill shape with source option))
then simply select the animated texture layer and erase it. now just delete the mask layer and your ready.
CartoonMonkey
Thanks for that! I agree, there are so many ways to do things with TVP. And I can't always come up with the best solution..
So thank you once again. All this for my next job, involving cartoon characters against live video.. Whew!
C
