Render storyboard
Ami
Render storyboard
Post by Ami »
Hi!
I have a problem when rendering storyboard. In the html version it begins from the middle. When i look at the image and gif files, there are all the scenes from 1 to the end. But they don't show in the html. Does it affect that my project is quite long about 8 minutes, and 70 shots. I marked the in and out point from beginning to end, does that affect? I hope this will be solved, because I need to get the storyboard pdf.
Ami
Re: Render storyboard
Dear Ami,
I know there was a small bug with the storyboard export a few months ago with the big projects.
It's now solved. Please make sure that you have the lastest version (9.5.16). If not please go into the Help > Update option.
Ami
Post by Ami »
Hey thanks, I downloaded the new version, it worked!
So great!
Ami
