Flip the images of an Animation layer
Posted: 18 Aug 2010, 15:14
I am new in this forum and beginner in tvpaint. So I have still a lot to learn. I am trying the features of tvpaint 9.5.16 by means of the tvp manual. But now and then the manual is not helpful enough.
So in the case of the Flip option of the layer menu, as discribed in lesson 4-11, which changes the sequence of images in the layer to the opposite order.
The manual says: "(This option) ... is only available in the layer menu after having selected the images to be flipped in an animation layer of your choice."
I did so, the images were selected (yellow bar underneath the layer), but the Flip option is not to be found in the layer menu.
Is this feature omitted in the new software version? Otherwise, I would be pleased about your help to find out, what I am doing wrong.
Of course, I could get the same result by doubling the length of the layer with the ping-pong option and then cutting the first part. But I would like to use the direct method.
Dieter
Dieter
