Retiming animation
Zippy
Retiming animation
Post by Zippy »
Hi,
I'm new with TVPaint and I was wondering if there's a way to retime an animation layer by dragging frames around?
Right now, the only way I could find is to select and copy/paste the drawings and then delete the original one but that's time consuming and awkward.
Thanks!
Re: Retiming animation
Read the manual part about instances and exposures. This is for retiming without re-ordering of frames.
If you need to change the sequence of frames, read upon Xsheet.
Zippy
Post by Zippy »
Oops! Forgot to say I'm using version 8.1 (I think)
So I guess I'm back to copy/paste then?
I was thinking along the lines of Digicel Flipbook, where you can drag and move the frames around to quickly adjust the timing.
Zippy wrote:Oops! Forgot to say I'm using version 8.1 (I think)
Woh O _o think in updating your software to the 8.6.2 version =)
