I would like to propose to remove the "can't be redone" requester. Or at least make it not block the soft untill you click it away. A simple sound effect to tell you you're at the and of your redo's should be enough, eventually combined with a small visual glitch. Or at least give us the option to turn it off. (Maybe this is already possible, and I didn't find it. In that case this whole remove feature request is obsolete)
Undo and redo is, at least in my case, and my guess is that I'm not alone here, a feature that's used A LOT. And almost every time I bump into this requester to be clicked away before continuing. Every time it breaks my workflow, and today is the day it bugs me this much I decided to write this request.
Re: remove the "can't be redone" requester
good idea. there is no need for an active confirmation there.
I do agree.
- malcooning
I think that generally some notification requesters can remain (they're useful for new users), but should become a message pop-up, at the top/side/bottom of the screen, which fades out by itself rather than requires confirmation, and which also does not interrupt the activity in the TVP. Furthermore, it should be made possible to turn it off in the preferences panel.
Asaf | asafagranat.com
Or perhaps a 'Don't show me this again' check box.
+1 Asaf, informative popups such as the ones done in javascript would work, something not intrusive but still visible.
