Papertrail Autohotkey Script
lemec
Post by lemec »
Creates a temporary blueline sketch that follows behind your cursor - Use this to make "airsketches" with the stylus by moving the stylus around without touching the tablet.
Lines are non-permanent and are confined to a small region of the screen that follows your cursor around.
Use it take "practise swings" and temporarily make markings on the screen without affecting your canvas or having to undo/redo.
Doubletap ALT to toggle it OFF/ON
Hold ALT to rapidly fade out the papertrail
Doubletap ESC to quit (or see the green task tray icon)
Tutorial is here
For PC only.
papertrail_tvp.zip
Papertrail_tvp.exe - Compiled TVPaint version (works for all programs but uses the ALT key for toggling and can be run standalone)
Papertrail_tvp.ahk - TVPaint version source code (if you want to modify it)
(208.78 KiB) Downloaded 3697 times
(Win7x64, TVP Pro 11 32-bit)
Re: Papertrail Autohotkey Script
hmmm, no demo video ? :?: :P
lemec
Post by lemec »
Maybe later, but for now I am running on a tight deadline.
malcooning
Post by malcooning »
Mark this is a seriously cool tool. inventive, intuitive and practical. well done and thank you for sharing it.
lemec
Post by lemec »
Glad you like it.
I will try to make some sort of options menu for it. (fade rate, line width, line colour, region size)
Hosni
Post by Hosni »
that's cool.... and the line of your papertail in your tutorial vid was awesome ... with line color and fading out... hope u add it to this script
