Help! master soundtrack doesnt playback inside a clip
Bernharda Xilko
Post by Bernharda Xilko »
Hello, i'm new to tvp so please excuse my ignorance.
My question is: is it posible to playback/scrub the master soundtrack inside particular clips.
My situation is like this: i drew a storyboard(animatik, with all timed key animation drawings) in one clip with the sound loaded inside and then broke it in few clips for further refinement into finished animation. Now i loaded the soundtrack that i used as a master track but when i go into timelines of individual clips and play or scrub my animation there is no sound.
Is it possible to do so or do i have to break the sound and load portions into each clip?
Thank you and excuse me if i dont use proper terminology
Re: Help! master soundtrack doesnt playback inside a clip
I assume you are in the Project tab, using the Timeline View (Forth icon at the top). After loading sound track look for little triangle sitting at the very head of the track's sound graph. Click on it to see the Options button. There you will find the option to Split Track to Clips.
Bernharda Xilko
Hello Paul, thank you for helping!
I did what you said but only options i find are lock, offset or delete. Is it the wrong options tab?
Oh yes, to give more information, it is a wav file, around twenty seconds long and i'm using tvp 9.5.3 pro version.
First, you should update to the latest version; it's free.
Bernharda Xilko wrote:Hello Paul, thank you for helping!
Please upgrade your product to the lastest version to get all the options. All the 9.5.x versions are free for people who have purchased a 9.x product.
Mads Juul
Post by Mads Juul »
Bernharda Xilko wrote: Is it possible to do so or do i have to break the sound and load portions into each clip?
It is not possible at the moment. But i do Animatics as well and I also miss this function so i will post it as a feature request.
-Mads
