Support for Dual Screen Monitors
It would be a great help to be able to drag toolbars from on screen to another when working on dual screens. As it is, it won't let me stretch across multiple screens, feels a bit convoluted.
Re: Support for Dual Screen Monitors
Check the settings of your video driver, and the settings of your toolbars. I am working with triple screen setup without a problem. There's no limitations within TVP. Solution to be found in the driversettings of your video card.
but make sure the TVPwindow is not maximized, only then can you stretch it manually over your multiple monitors.hilere wrote:... There's no limitations within TVP. ...
- malcooning
or work in "no border" mode.
It's in Edit > Preferences > Interface
If you want to be able to toggle this mode quickly, make a custom button and assign shortcut "TVP Animation: No Border" to it.
Asaf | asafagranat.com
yes but detachable windows are a great comfort
your 2nd screen isn't necessarily as big as the 1st (cintiq?)
en then you need any space you can get
I would like to get rid of the menubar sometimes for example.
A work/zoom window (shortcut m) which I could bring "out" of tvpaint and maximize there would be great
