can i group anim layers without mereging them
Posted: 11 Jan 2011, 16:54
by mazivco
hello
i like working with layers so i can apply different effects and go back and make changes in a non destractiv way
the only problem is that it takes to much space in the time line and ccan be very confusing
so i was wondering if theres a way to group some layers together an bhing able to ungroup them later on
like pre compes in aftereffect
thanks for the help
Re: can i group anim layers without mereging them
Posted: 11 Jan 2011, 17:50
by Byron
Hi
You can minimise the layers you're not currently using (with the black triangle icon next to the layer name) so that they take up lass space, and you can group layers by colour (using the little 'c' icon) and then use the colours at the bottom of the layers palette to manage which colour groups are hidden/locked/selected etc.
Posted: 13 Jan 2011, 06:17
by malcooning
Mazivco, to answer your question shortly, currently there is no way to group layers, and there is no nesting or pre-comping in TVP.
The nearest thing you can do is use the Keyframer and set another project as a source layer, but it will not give you a non-destructive workflow.
My 2 cents on this: TVP has it's own way, and it is not a compositing software. Try not to have compositing 'expectations' from TVP and you'll soon find what makes it fantastic.
Posted: 30 Jan 2011, 00:34
by dperro
Would "linking" layers be helpful in what you want to do? You can create a custom tool to do that.
Make a tool icon in a Custom Panel, then click "Edit", then "Set Keystroke", then "Layer", then "Link".
To link layers, hold down Shift then select the layer icons in the timeline to select them (you'll see yellow borders around the icons).
Click your new "Link"tool and you should be able to have them linked. For some reason, the lower layers shift one frame to the right...I'm trying to figure out why.
