Problem with cursor
Litalmo
Problem with cursor
Post by Litalmo »
First post here so hi everyone! :D
When I use the pencil tool I get broken, angular lines. I think there’s a slight delay with the cursor. I’ve also noticed that when I choose the smooth-best option, it gets worse: I have to wait for a whole second till the stroke is done forming and the result is very off.
I have windows 7 64 bit and I use a cintiq.
Re: Problem with cursor
Hi Litalmo, Welcome in the TVPaint Community !
Which version of TVP Animation do you use ? Did you think to update it ?
Litalmo wrote:First post here so hi everyone! :D
Please can you post a screenshot of the result when you use those settings ?
[ EDIT ] : In fact, I'm not sure if you are speaking about the "Smooth Best" option of the brushes or the "Smooth" of the lines.
It can also comes from Windows or the Wacom drivers if they are configured to search if you keep the left mouse button activated.
Anyway, please post a screenshot, it would help us to answer your question.
Litalmo
Post by Litalmo »
ok, so I’ve restarted my computer and the problem seems to be gone for now. still whenever I switch from smooth medium to smooth best I get the delay.
You can see in the image how when I attempt to draw a circle with the smooth best selected (on the right) it gets distorted (as appose to the circle on the left) because of the delay-I wasn't going for a spiral. also I have the latest version of tvpaint.
Litalmo wrote:I have the latest version of tvpaint.
which one ?
Litalmo
Post by Litalmo »
9.5
Litalmo wrote:ok, so I’ve restarted my computer and the problem seems to be gone for now. still whenever I switch from smooth medium to smooth best I get the delay.
The "Best Option" of the custombrush panel is not intended to be used for drawing, but to place/move very big brushes on the workspace without loosing quality.
If you draw, just use the "medium option", you computer should be able to handle it. :)
Also, please make sure you have the 9.5.18 version to avoid any old bug.
Litalmo
Post by Litalmo »
ok thanks :D
