Linking Layers
Linking Layers
I have no idea how to phrase a search of the forum for what I am about to ask. Is it possible to links layers so as one layer is moved, the other layer follows? If this is not clear I will try and phrase it in a different way.
Re: Linking Layers
Highlight the thumbs of the layers you want to move together and move one.
Re: Linking Layers
Sorry but I still have linking layers issues. I wont to use the transform tool but it will only move one layer.
Re: Linking Layers
"Enter" key is the way to go.
Re: Linking Layers
This was the only command combination that did what I wonted. Alt/Option Left mouse button.
Re: Linking Layers
I have no idea what you are talking about anymore. Your question sounded so straightforward to me because it is something I do all the time the way I answered it. But Alt/Option...??? Option where, of what? I'd like to learn something new.
Re: Linking Layers
Sorry, I do need to learn to be more descriptive. I have a source image that I am tracing but I need to rotate the two layers in unison. I was trying to use positioning button to do this but it only moves one layer. Locking the layers really locks the layers, I could not do anything, so that was not working.Paul Fierlinger wrote:I have no idea what you are talking about anymore. Your question sounded so straightforward to me because it is something I do all the time the way I answered it. But Alt/Option...??? Option where, of what? I'd like to learn something new.
I fell into the solution when I was told one of the hot keys was the "page up" and "page down" button. A quick test pressing a combination of control, alt/option, and the apple key gave me the answer. Mac computer has a button called alt/option and with the up and down button I can now rotate all canvas layers. I am very green with all this but I will try and be more descriptive of what I am trying to do. I will also try and find the PC equivalent but no promises.
Re: Linking Layers
Thanks; all clear ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Re: Linking Layers
Well, it looks like I still need some help with the layers. I wont to rotate one layer on the table but not rotate the other layers. Is there a way of doing this with out setting up different projects.
I have multiple images of the same object from different view points. I trace my first source image then I wont to aline the new second source image with the first image, then make changes to the drawing.
This is slightly related, I can not import the same image into multiple projects.
Re: Linking Layers
hmmm, not sure it will help, but can't you use the "out of pegs" feature of the lighttable ?
Re: Linking Layers
Thanks you, I will look into. I am very red faced now because I never looked at the panel controls. That is going to have to be part of my mantra. The transform tool panel as a place to choose the angle to transform.
If the light-table works too, then I will have even more power in my hands. Thanks you for the quick response.
