TVP Import Dialogue Box On a Mac
Posted: 12 Feb 2011, 23:37
by hilary
Hi -
I have just installed TVP 9 Pro on my MAC and used it all day yesterday with no problems - but today when I try and import footage I keep getting the MAC system file browser window and not the TVP one - if I choose my file (in his case an audio only QT) and then click LOAD nothing happens...I rebooted a couple of times but it still keeps happening - did I change something by accident in preferences? Normally the MAC dialogue box has the option to OPEN but mine is saying LOAD now? Which is making me think its a set up preference issue. Any ideas?
Cheers,
Hilary
Re: TVP Import Dialogue Box On a Mac
Posted: 13 Feb 2011, 00:36
by Paul Fierlinger
I'm not familiar with the MAC version, but in the PC this is selected as a preference under Edit>Preferences>Interface/File requester/TVP Animation Pro.
Posted: 13 Feb 2011, 09:08
"Load" is OK, so it's no matter of preferences. But of course it should work.
Did you try other kinds of sound file? I'd recommend AIF or WAV - sound within a Quicktime file can be using a codec TVP doesn''t understand.
Posted: 13 Feb 2011, 13:50
hilary wrote:Hi -
That is a little quirk of TVP ... from the File Menu it says OPEN , but when the file browser appears it says LOAD .
LOAD = same as OPEN .
- TVP_OPEN.jpg (40.16 KiB) Viewed 15963 times
- LOAD_Images.jpg (40.11 KiB) Viewed 15963 times
Posted: 16 Feb 2011, 04:32
by hilary
Thanks for the info everyone - Paul my preferences were on SYSTEM instead of TV Paint so I changed that and was able to import footage again. The audio file I mentioned still wouldn't import though. Does anyone know if there are certain QT codecs that are incompatible with TVP?
Cheers,
Hilary
Posted: 16 Feb 2011, 08:14
Do you import your sound file from "File => open" or from the "sound space" in the timeline ?
You must load a sound (mp3 or wav) here :
- loadsound.png (15.86 KiB) Viewed 15939 times
Posted: 17 Feb 2011, 03:06
by hilary
Its actually a QT file that was rendered with audio only. But I will re-render it and see if it works bringing it in as a WAV. Thanks Elodie!
Hilary
Posted: 17 Feb 2011, 03:15
by hilary
Ok so once I re- rendered the original QT to a WAV file and then loaded it through the time line at the top as instructed it worked. But I tried bringing the WAV in first through the 'import footage' and it didn't work. So does all sound need to go through the 'load soundtrack'?
Thanks,
Hilary
Posted: 17 Feb 2011, 07:58
Yes, of course !
"Import footage" is for images and videos only
