for a paper structure i needed to even out "alpha holes" in semi transparent area's.
i managed to to do this by merging a semitransparent layer using "Alpha diff mode while merging.
still figuring out the ammount of transparency was trial and error.
is there a way to messure the alpha value of a pixel?
i tried the coordinate panel but it only gives RGB values and no alpha.
how to measure alpha values
Re: how to measure alpha values
Hello Peter,
I'm not sure to understand what you want to do, but I think that the "FX > Color > Histogram" may help. There is an alpha tab inside.
i guess its a bit tricky to explainFabrice wrote:Hello Peter,
but i need to close or "heal" holes in a layer that is not 100% opaque
so say i have a layer that is 50% transparent but it has parts that are 100 % transparent (the holes)
i now want to fill these 100% holes so the whole area is seamlessly 50% transparent.
this is possible with an alpha diffmerge but only if you know that the transparency value of the layer i need to fix is indeed 50%
thats why i was looking for a way to find out what % of transparency a pixel has ( what alpha value).
The Histogram FX seems to display a graph of the Alpha info in an image but i don't see how i can get a usefull opacvity% out of it.
I was thinking along the lines of the colorpicker but then an "alpha picker"
Feature request?
not totally clear to me, but haven't you the RGBA values in your infobar when you roll your mouse (cursor) over the canvas ?
if you need the alpha info of a single layer, hide all others.
if not a solution for your specific case, you can consider to write a little script and get the "right" Alpha value,
using one of these commands (regarding your needs) :
Note that the returned A value is from 0 to 255, not in % opacity (0 to 100).
btw, I remember Manuel have done and shared (far ago) a george script called "PickColor+Alpha" or something,
notg sure, but maybe it's just what you 're looking for actually ...
tv_PicColor
tv_GetPixelDisplay
tv_GetPixelLayer
It looks like it only shows the alpha of the selected layer? No need to hide the others.
wow Thanks Zig,ZigOtto wrote:not totally clear to me, but haven't you the RGBA values in your infobar when you roll your mouse (cursor) over the canvas ?
a clear case of Doh!
