quick question. Do layers in tv paint have clipping masks? And by clipping mask I mean the feature found in photoshop in which information will be constrained to an already existing image.
for example if i make a brush stroke, then want to put another brush stroke over it, but do not want to change the shape of the brush stroke, is this possible?
It's sort of hard to articulate what clipping masks are so, anyone who knows what they are. Does tv paint have them?
clipping masks in tv paint
Re: clipping masks in tv paint
not very clear to me ... can you post an image to illustrate what you're looking for ?madteo wrote:... for example if i make a brush stroke, then want to put another brush stroke over it, but do not want to change the shape of the brush stroke, is this possible?
Click here :
(white square => you can draw only where a pixel already exists / black : you can draw only where a pixel doesn't exist yet)
Concerning your brush, you simply have to put it on your drawing space,
active the stencil and change, for example, the color :
Then, use the tool that cut custom brushes and draw with your new colored brush.
perfect thanks very much!
Hi Elodie,
I used that Clipping Mask you recommend here in the past, to give some parts of a lineart a new color. But I have noticed, that there is a problem at the margins (borders) of the strokes where the half transparent pixels are. They stay a little bit shaded und you'll get a ugly colored line. I also noticed that this is not happen when using the "preserve Transparency" function from the top of the screen. That is what I would recommend here.
- Maybe there's something wrong with the "clipping mask" from the layer check boxes. Here is a picture to demonstrate what I am talking about.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
- ClippingMasks.jpg (37.76 KiB) Viewed 20059 times
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
There is nothing wrong in fact. Just two different ways to do the calculations.
Indeed, you have to test the two possibilities.
I've never used that "preserve transparency" - thx for that tip! I just used the stencils with a "good enough" result.
