assigning Alt Gr functionality
malcooning
Post by malcooning »
hallo.
Is it possible to assign the 'Alt Gr' key the same functionality as 'Alt' key. I mean, in one of the workstations I have a keyboard set with Alt on the left of the spacebar, and Alt Gr to the right of the Spacebar. I don't want to reach for the far left Alt in order to pan with the mouse, so I want to use Alt Gr as the Pan one.
In case I made myself clear, is it possible?
cheers
TVPaint
Post by TVPaint »
Hi malcooning !
AltGr is considered as Ctrl + Alt on windows.
So the solution would be to set the keystrokes on Ctrl + Alt (which is by default set to do the rotation of the work area).
Anyway the main problem is that there is no george command script to do the same kind of pan...
But i'm sure it will come with an incoming update...
Stay tuned !
Regards,
N.
