Toggling the DISPLAY checkbox in Tool:Cutbrush options
It would be nice to have a way (in George and in shortcut keys) to toggle the DISPLAY check box that governs whether a cutbrush captures from only the current layer or from all visible layers.
Also, if you had such a toggle DISPLAY check box command in George, it would also make sense to be able to test the current status of the Display check box (checked or unchecked) in a script.
I know this would make Mark happy - The Isolator
Thank you.
Re: Toggling the DISPLAY checkbox in Tool:Cutbrush options
and as we are on this, I untomb one of my old request, called "Deep Selection",
why not to have this "toggle Display" option in the [Selection /Copy to Layer] and [Selection /Copy to Brush] as well ?
Fri Feb 26, 2010 5:29 pm
ZigOtto wrote:yet another request : "DeepCopy Selection" in the Selection Tools panel,
or Copy to Layer [D] and Copy to Brush [D] :
when a selection is drawn, [Copy to Layer] and [Copy to Brush] work only on the current layer content,
whatever the CutBrush / Display option is set ON or OFF,
why not to have the Selection /[Copy to Layer] and [Copy to Brush] working regarding this "Display" setting ?
I mean when Display option Off, it will get the current layer's content only (as it works now),
and when Display option is ON, it will copy the display (all visible layers flattened) content of the selection,
except the BG when it's not to None, preferably.
or maybe a separate [Display] option to toggle On/Off in the Selection Tools panel (see pict.) ...?
+ having 2 pop-up menu where you could choose :
• the action : cut or past
• the destination : brush, instance, layer or clip.
Mads Juul
Post by Mads Juul »
It could still be nice. to be able to read/and write the Properties of the Cutbrush with George
Especially the Display setting.
