question about full screen mode
cbandla
Post by cbandla »
I'm having an issue when working in full screen mode. When I start TVP 9.5 standard edition and put the display in full screen the image area will scale down when I scale up the layer panel. After I work for a while the image area stops scaling in response to the layer panel. Has anyone else run into this? What am I doing and how can I get it back?
Charles
P.S. If I restart TVP it works again.
Charles Bandla
TV Paint 11.0.8 Pro Edition
iMac 21.5"/ 2.7 GHz i5 quad core/12 GB Memory/1 TB HD/OS X 10.10.5 64bit & Ubuntu 16.04 64bit
Dell Precision M4700/ 2.8 GHz i7 quad core/16 GB Memory/500 GB HD/Ubuntu 16.04 64bit
Cintiq 12 wx
malcooning
Re: question about full screen mode
Post by malcooning »
Probably something breaks the 'Fit project window' function.
Make sure you toggle the button on.
cbandla
Post by cbandla »
Thank you. I'll check that the next time it happens.
Charles
