Does anybody know how to disable the toggle Marks (yellow line under the drawing window)
they prohibit me to draw
Thanks
toggle marks or yellow stripes under drawing window
- malcooning
Re: toggle marks or yellow stripes under drawing window
Not sure which mark you referring to.
can you post a screen grab?
Asaf | asafagranat.com
I think the line is the one just below and in between the 'Markin' and 'Markout". Not sure how that would keep someone from drawing.malcooning wrote:Not sure which mark you referring to.
I think he means that yellow line :malcooning wrote:Not sure which mark you referring to.
In fact, that yellow line shows you the current image. As you only have 1 image, all the line becomes yellow. But if you add several images :
Only the current image will be yellow and so, the "yellow bar" will be thiner =)
Yellow "toggle Marks" ...?
if it's what Elodie pointed in its interpretation, you can use the Toggle UI Visibility command,
the little black triangle in the preview window's top bar, and use shortkeys for reaching/using the hidden commands.
