Splines? - I'm New!! Help!
TVPaintUser
Post by TVPaintUser »
  • How do you get rid of splines?? What are they!? I have no idea.
Re: Splines? - I'm New!! Help!
More information is required to provide a precise answer.
If you have no idea what splines are then how did you get them in your TVP project ? (because you have to select
the spline tools in the TVP Main Panel to activate the splines) What exactly are you trying to do with splines ?
To get rid of splines simply select a different tool in the Main Panel .
Splines are explained in the TVP USER MANUAL , section 2-14 - to - 2-15 and in the APPENDIX to the USER MANUAL Section C page 9 - 11 which explains the tools in the "The Main Panel" (including spline options) , and Section F "New Line and Spline Options" on page 24.
The TVP USER MANUAL and the APPENDIX are on your TVP install disc and should have installed to your TVP Animation folder in your applications folder when you installed TVP, or if you can't locate the User Manual and the Appendix then you can download them here:
http://www.tvpaint.com/v2/content/artic ... manual.php" onclick="window.open(this.href);return false;
