exporting without background
Posted: 26 May 2011, 20:05
by cumbaraquimbara
Hi
I'm trying to export an animation without background, with this method:
- Export to: animation, not background, quicktime
but the final result is a video with black background. The original layers in TVP donĀ“t have background (shift + B). I need the video without background to make a composition in After Effects.
How do I get a video without background?
Suggestions?
GR
Re: exporting without background
Posted: 26 May 2011, 20:33
by Paul Fierlinger
What I do is Export:
Set Layer Panel at the bottom left to NONE
Export: AVI
Config: Uncompressed (BGR 32)
Mode: RGBA (32 Bits)
Background: unchecked
Maybe it's the NONE or the unchecked background that you have missed. If done correctly you must see a checkered background in your Export Panel to know that it will work.
EDIT: I just checked using QUICKTIME>Animation instead of AVI and with the same settings as above and it should work.
Posted: 26 May 2011, 21:41
by cumbaraquimbara
thanks, that's right
I forgot to chose the rgb 32 mode.
GR
Posted: 21 Jun 2012, 02:50
by suza
Thanks alot! i've trying to find a way to solve the same problem...and this thread just what i needed !
