Stretch a frame to the left
Boomslang
Post by Boomslang »
This is always bugging me, you can drag a frame to the right, but not the other way around so you have to work around it in a weird way. Might be handy if you can stretch it both ways?
Sewie
Re: Stretch a frame to the left
Post by Sewie »
Yes you can... What frame handles do you use?
(And why is this posted in 'Contents Sharing'?)
Boomslang
Post by Boomslang »
Ah, sorry, thought it was feature request..
Sewie
Post by Sewie »
No problem.
Did you figure it out, though? You can use any of the handles on the frames in the timeline.
Boomslang
Post by Boomslang »
I just purchased TVpaint 9, (still waiting for the unlock code), so I have the normal standard handlebar. As you can see, there's only a square on the right side, and I'd like there to be one on the left. Is there a way for that? Thanks
Boomslang wrote:I just purchased TVpaint 9, (still waiting for the unlock code)
You've just asked for it... Please, let us the time to get our emails, read them and answer them ¬_¬
Boomslang wrote:As you can see, there's only a square on the right side, and I'd like there to be one on the left. Is there a way for that? Thanks
Not sure it should be useful.
Boomslang
Post by Boomslang »
Uh I wasn't being impatient about the unlock code, did I came across that way? I'm sorry. :oops: Do take your times! :wink:
Anyway, I find it would be handy, because sometimes when you animate on a layer you want to stretch it to the left, now the method is just to stretch it to the right and delete the frames that preceed it. It's kinda hard to explain, sorry. Maybe there is an easier way that I don't know about.
Boomslang wrote:Anyway, I find it would be handy, because sometimes when you animate on a layer you want to stretch it to the left, now the method is just to stretch it to the right and delete the frames that preceed it. It's kinda hard to explain, sorry.
No, I understand, you're right, it's interesting if the first instance doesn't start on the image "0"
In theory, grabbing the left bar with the option "add empty exposures" should do it. However, it adds two instances which is a bit confusing.
Mads Juul
Post by Mads Juul »
And why isn't there a instance handle in the top left corner of the first instance of a layer?
Maybe that should be a feuture request to add a instance handle in the top left corner of the first instance?
-Mads
Boomslang
Post by Boomslang »
slowtiger wrote:In theory, grabbing the left bar with the option "add empty exposures" should do it. However, it adds two instances which is a bit confusing.
Well what I mean is that you can drag the instance to the left and that the rest of the frames that preceed it also shift to the left. Exactly the same as what happens when you drag it to the right. But I guess this wouldn't work because the left side isn't infinite, like the right side. Frames would have to be erased in order for it to work.
madsjuul wrote:And why isn't there a instance handle in the top left corner of the first instance of a layer?
-Mads
Indeed !
I already requested this (more then a year ago)
But it wasn't picked up
(i did find out though, that there is no proportional correlation between the font size of a request and the speed of its implementation.... :wink: )
FR-handle missing.jpg (25.78 KiB) Viewed 6544 times
Peter Wassink wrote: i miss having a "question free" instance length control (or startpoint control) on the first instance, its the only instance in the layer that does not have it and i cannot think of a good reason why.
adding this would make the layer control, faster, free-er and symmetrical ( you can push and pull the end and begin point of all instances except the first)
it got only one response then; from Paul:
by Paul Fierlinger » 01 Mar 2010, 12:19
Can this really be done!? I've never asked for it because I thought it wasn't possible. But if it can be done, please let's have it soon ...
Peter Wassink wrote:(i did find out though, that there is no proportional correlation between the font size of a request and the speed of its implementation.... :wink: )
this request don't really deserve huge font imo :wink:
... it doesn't miss so much to me, because :
1) I rarely need to lengthen the first instance left-side over the starting frame (before frame 0),
2) if I do, I simply drag the left-handle, and set the "increase layer length" option to Repeat/Exposure.
ZigOtto wrote: this request don't really deserve huge font imo :wink:
my projects often have dozens of layers most of which don't start at frame 1 (or 0)
believe me.... this request Does deserve a big font!
Mads Juul
Post by Mads Juul »
I personal in my woekflow don't need the handle on the first frame. But I think that it is unlogical that it is missing. that is is a inconsistency in the interface, And I don't like that. So I think it a top left layer handle on the first instance should be added.
-mads
