Hi
I recently bought a cintiq 21, but his default setup don´t works with TVP, I can only change the brush zise with the sliders, not zoom.
are there tvp cintiq presets?
thanks you
cintiq presets
Re: cintiq presets
Edit your wacom's preferences and set the keyshorts you want.
Re: cintiq presets
Hello Gerardo,
Did you success to make it ?
We can post some screenshots if required.
Re: cintiq presets
In TVPaint many shortcuts are not like in other regular programs. For example – standard Wacom scroll/zoom doesn't work this way. You can check the keyboard shortcuts inside TVP settings, and then assign what you need on the Cintiq (in Wacom preferences). I use the native ALT+Right click to zoom, ALT+Click to pan, and CTRL+ALT+Click to rotate. All this is set up on my Cintiq (The ALT, and the ALT CTRL keystrokes), and its very easy to use. There are many other TVP shortcuts, almost for everything in the program, so you can assign what you need in the Wacom preferences.
