Blending brushes
Blending brushes
Is there any way to create blending brushes in TVPaint. How would you blend to colors together smoothly. I know this sounds like an amatuer question, but I am curious. Any links or ideas would be cool. Thanks in advance.
Re: Blending brushes
hi maestro,artmaestro wrote:Is there any way to create blending brushes in TVPaint. How would you blend to colors together smoothly. I know this sounds like an amatuer question, but I am curious. Any links or ideas would be cool. Thanks in advance.
what do you mean exactly by "... blend to colors together smoothly" ?
meanwhile,
- you can have a look to the "specialBrush" tool (mixer mode) working as the color Mixer in the Color Picker Panel;
(not sure it's what you are looking for ...)
- another approach to modify smoothly a color by mixing it with a new one, (color management only),
is to use the excellent Lemec's "PPalette" external tool which is part of the lemec-plugins.
Thanks for the responses. After playing around with demo some more, I figured out what I wanted to do. I was looking to blend skin values together i.e shadows, fading into other areas without a distinct line. I included an attachment to show the look I was going for (look at the facial area). I adjusted the special tool to smear a little better. I haven't fully tested it, but I'm thinking it might work for me. I asked because I was thinking about the blending tools in Painter - since this software works similarly. I think it's neat to have quality real media tools and quality animation tools if needed together. This is why I'm really digging into this software. Again thanks for the help.
- 2006alien28_6.jpg (156.8 KiB) Viewed 20867 times
wow
, good work !
I thought about something else :
Some drawing mode are available with the common tools : (tint, colorize, saturate, add, etc ...).
they can be used with papers and help you to colorize your paintings.
- artmaestro.jpg (38.45 KiB) Viewed 20858 times
That is not my work, though I wish it werefabrice wrote:wow, good work !
