Color lables selection icons
A forum where you can suggest which features can be deleted or merged with other options.
Soom
Post by Soom »
On the left bottom of the Timeline there is this huge row of color squares used to select which colored layers we want/don't want to see. I think they can go into one stacked button and clear up space in the timeline.
Mads Juul
Re: Color lables selection icons
Post by Mads Juul »
I think there maybe could be a more elegant solution.
Maybe the Show/Hide layers could be part of the vertical color popup when you click the "Layer Toggle Flags"?
For instrance I think the "Select the layers of this color" function should be connected to a layer so You know that you will select the the layers with the same color as the layer you clicked.
-Mads
Soom
Post by Soom »
madsjuul wrote:...For instrance I think the "Select the layers of this color" function should be connected to a layer so You know that you will select the the layers with the same color as the layer you clicked.
-Mads
Good idea!
