HDD crash .. installing new one...
masterchief
Post by masterchief »
I need help installing TV Paint PRO v9.5 ... I have a library of updates... none seem to get it done. Please advise.
TVPaint Animation Pro v11
Re: HDD crash .. installing new one...
Hi Masterchief.
What are those "library of updates" you are talking about ? TVPaint doesn"t ask for any update and let you take the decision by yourself.
Are you on PC or Mac btw ?
masterchief
I always save my updates to disk .. and I have lots of them. not really doing me any good at this point. LOL
I am using a PC .. Windows XP Pro/32
UPDATE - I have a library of installer files
I was in your situation just this month. Didn't lost any data (nearly), but it was a tedious and time consuming process to re-install all software, drivers, preferences, and what not. Lost 2 programs though because they used hard drive authorization, and the faulty drive was only partially readable and didn't boot anymore.
TVP is not that problematic in such a situation. You can always download the installer file from the website, if you forgot to keep it (I keep installer files on an external disk.) But you may lose all your presets and brushes!
I spent several days until I could fix that. TVP creates a folder (Mac version:) start disk/users/[me]/library/application support/tvp animation 9 pro/default (or [mine] if you ever saved your own configuration.) This folder is the one which holds all your shortcuts, panels, brushes, swatches, and so on. Copy it to an external disk, copy it back onto a new start disk, and it will work like a charm.
My problem was that I had too many of these folders, for example one at start disk/library/application support/tvp animation 9 pro/[mine] - it looked the same, but it wasn't the same content! I guess previous versions of TVP stored it in different ocations, adding much to my confusion. It also doesn't help that anything inside these folders is just named completely cryptical.
masterchief
I need tvpaint to reissue my lock code and unlock codes so that I can download direct from them.
Ouch. That's the first thing I do after purchasing software: copy those codes to as many placs as possible, and write them down.
masterchief
I was a Mirage crossgrade..
update - found my QuickTime PRO reg code... LOL
update - installed TVPanint, now get a lockcode to report. how to identify the dongle ID???
Mine has a dog tag with an 8-digit number.
Patrick
Post by Patrick »
Hi Masterchief
No problem, you are in our database so I will send you the codes by pm.
masterchief
Patrick wrote:Hi Masterchief
thank you my friend ... my copy of TVPaint is running in 30-day license mode until codes are entered. It is licensed to my name already.
UPDATE - I have one of those Thermaltake dual external drive device .. plugged in my failed drive and all the data is recoverable. whew!!! It just wont work for booting the computer anymore...
