Is there a straightforward way to set up a walk cycle, (in the form of an animated brush), with forward movement using the keyframer, such that the feet neither slip nor slide, or is the whole thing done in a trial and error fashion?
Thanks,
Greg Smith
Timing Walk Cycle with Forward Motion to Path Length
Giving the experiment a few more tries, I realized that not much time is saved by using a path to chart the course of a walk cycle, and, the results are inferior to just stamping the brush, (aligning the stationary foot of each stamp), frame by frame. This way, you get absolute solidity of step. Really very fast and rewarding.
Thanks,
Greg Smith
Thanks,
Greg Smith
that's a good point, Greg, and I often do the same way (frame by frame),
specially when feet's contact spacings aren't regular enough from one drawing to the other...
"Trial and error" method isn't so bad although ... ;
otherwise, it's mathematical :
a full cycle distance (on ground) D = 2x 1 step ,
suppose your step = 220 pixels long, so D = 2x 240 = 480 pixels,
suppose your walk cycle's made with 16 drawings, in 2's,
if your cycle is animated "on place", you should displace it at :
d = 480/16 = 30 pixels, for passing from one drawing to the next,
Now in KeyFramer (source = custom brush) :
to cross (in > out) the video frame (720 pixels long),
your animated brush should start, say at X1 = -120, and stop (to be completely off) at X2 = 840,
so you get a path length of : Xp = X2 - X1 = 960 pixels to cover with your AnimBrush,
guess how many frames you need to achieve this crossing walk without " slip nor slide" ?
... 960/30 = 32 frames, ... 2 full cycles, or 4 steps!!!
coincidence??? sometimes mathematics are Magical!...
ps: if your project's frame-rate is 12.5 (pal) or 15 (ntsc), that's all, nothing more to do,
if your project's frame-rate is 25 (pal) or 30 (ntsc), "select all" and "duplicate = 1",
so your animlayer should be now 64 frames long, and the speed OK.
- cycle-length.png (41.04 KiB) Viewed 16042 times
... mentionned (in other words) in the first lines of my previous post .Manuel wrote:@zigotto : need to add that the feet must move in a regular linear timing (as you wrote "d = 480/16 = 30 pixels").
If you have to animate "a silly walk" , you get probably some sliding.
The better is to apply by hand, frame by frame.
ZigOtto wrote: ... and I often do the same way (frame by frame),
