Ruler Tool
Ruler Tool
Here's a simple tool to measure the number of pixels between two points you select in the frame.
Ruler Button.png (9.13 KiB) Viewed 4394 times
RulerTool.tvpx
pixel ruler button
(57 KiB) Downloaded 448 times
To install:
Drag TVPX to interface and drop. You should see the ruler button in the Ruler Tool panel.
To use:
Click the icon, then click and drag the crosshair cursor, drawing a line along the length you want to measure.
The resulting line's length in pixels will be displayed in the infobar at the bottom of the TVPaint interface.
Click again to dismiss the line and reload the tool you were using.
any problem? post a description... thanks
idragosani
Re: RulerTool
Post by idragosani »
Very cool little tool, does one thing but does it very well :-)
Re: RulerTool
Thanks Svengali, this is something I never dared ask for.
Animark
Re: RulerTool
Post by Animark »
Hi,
it works on 9.5.21 on Win7 64 - no problems :-).
Before I used the line tool and the coordinates panel to measure, but your tool is more comfortable. Thanks.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
Animark
Re: RulerTool
Post by Animark »
Oh, there might be one misbehavior when using the ruler. When the ruler-line is visible you are not able to quit using the top right "X".
malcooning
Re: Ruler Tool
Post by malcooning »
great tool Sven.
a very welcome addition.
thanks.
Soom
Re: Ruler Tool
Post by Soom »
It's a nice tool, but unfortunately not as useful as could be. It would be much better, if it could display the length while dragging, not after. If there is no way to know the distance while dragging, it's impossible to repeat the same measurement, or to adjust it...
