can anybody suggest how I can create a custom button that will:
1. select all other frames on the layer (all the ones apart from the one the timeline cursor is on.
2. and then repeat last action (like pressing 'Enter')
Cheers,
A.
button to select all other frames
- malcooning
I suggest, instead of selecting all the other frame except the current one, to do something like that :
- Undo
- Select All Frames
- Shape Apply
It seems to work fine regarding the few tests i made.
Do you need a bin with the custom button ? Let me know, i can post one quickly.
Regards,
Nicolas
Edit : i finally did it :p
Just load by LMB clicking the CustomPanel icon and select Load, meaning you will load it from where it is but i suggest to place it in the plugin directory
- Undo
- Select All Frames
- Shape Apply
Regards,
Nicolas
- undo_selectall_redo.zip
- (482 Bytes) Downloaded 1209 times
