TVPaint 10 issue- wandering pallets
Posted: 15 Dec 2011, 17:43
by djsolomon
This might be something that the programers might take a look at check out the upper right of the photo
there is a pallet stuck up there... I opend the program and there it was... I will restart to see if it clears the issue but
though the tvp people should see this...
my best djsolomon
tvpaint 10 issue-system error
Posted: 15 Dec 2011, 18:05
by djsolomon
See wandering pallet note...
I reinstalled and got this error message
has anyone any idea what the problem is?
thanks
djsolomon
Re: tvpaint 10 issue-system error
Posted: 15 Dec 2011, 18:33
by idragosani
You have invalid plugins installed:
http://www.tvpaint.com/forum/viewtopic.php?p=11763" onclick="window.open(this.href);return false;
Posted: 15 Dec 2011, 18:55
by djsolomon
Hi idragosani , thanks for your repsonce... so I uninstalled
and clearly something is still funky as they pallets are still tucked up under the menu bar when i open the program
I really cant work know that clearly there is something wrong here...
what do you think may be causeing this ?
thanks djsolomon
Posted: 15 Dec 2011, 19:01
by idragosani
That I can't say, hopefully one of the TVP gang can help.
Posted: 15 Dec 2011, 19:10
by djsolomon
Hi idragosani- thanks again for your note..
No tvpaint gang yet...
how does one summon them ?
djsolomon
Posted: 15 Dec 2011, 19:15
by masterchief
djsolomon wrote:Hi idragosani , thanks for your repsonce... so I uninstalled
thanks djsolomon
where is your palette found?? where did you go to select it for display on your desktop?? I do not see that palette on my system
Posted: 15 Dec 2011, 19:22
by djsolomon
its the color variations panel, click around where the tools and panels are
you should see it
Posted: 15 Dec 2011, 19:23
by masterchief
found it... never used that.
Posted: 15 Dec 2011, 19:41
by idragosani
djsolomon wrote:Hi idragosani- thanks again for your note..
They are probably closed down for the day (it's evening time in France now).
Posted: 15 Dec 2011, 20:11
by ZigOtto
djsolomon wrote:...
hi djs
I've no idea what's causeing this,
but you can try to start with a new config,
just to see if it solve this upset panel issue.
Posted: 16 Dec 2011, 07:35
Sorry for the delay Debra, but as Idragosani said, we were closed when you wrote (8.00 PM in France)
I don't understand how you obtained that. Do the Variation panel opens like this the first time or did you put it there ?
As Zig suggested, I propose you to start a new configuration (start TVPaint and hold [Ctrl] to open the start up panel).
Posted: 16 Dec 2011, 10:25
I had the same problem in v9.5 once with the papers panel: somehow I managed to drag it so high under the toolbar that I wasn't able to drag it back. This remained for weeks, until one day I was able to click exactly the one pixel which allowed me to drag it back. Strange.
