Sticky display of certain layers
Posted: 03 Jan 2012, 12:58
I really love the Show all layers or show only current selected layer function (that "H" button in the display settings of the layer manager)
but I wondered if it was possible to improve this behaviour to assign soms layers to be always visible regardless of this mode. By marking these layers in some way,they remain visible.
This because when you are cleaning on different layers (arms,head and so forth) you can set 1 or more layers as reference layer to clean the lines from. And quickly switch between the layers automaticly hiding the objects not needed on that layer,that are already cleaned,but still showing the reference layers that you need always.
Another example is for comparing different colors against the same lineart (on seperate layer) quickly.this makes it a one button operation to check and flip between multiple versions of same lineart.
If this is not possible I would like to make it a request.
So simply said: an option for certain layers to ignore the "show only current" behaviour.
without adding more to the UI it could be placed in the visibility button (the green-red one). And for example is activated by CTRL+Clicking the visibility button on the layers which need to be exluded. And you could get some green cube with an H in it,or even another color (blue?). Clicking it again would remove/toggle this function.
