.tif import
Posted: 29 Feb 2012, 14:58
by BenEcosse
For some reason I can't import a .tif file into to TVP 10.
Re: .tif import
Posted: 29 Feb 2012, 15:02
by ematecki
What is the format of that tiff file ?
TVPaint doesn't support CMYK tiffs.
Re: .tif import
Posted: 29 Feb 2012, 15:27
by BenEcosse
RGB 16bit uncompressed
Re: .tif import
Posted: 29 Feb 2012, 15:31
by idragosani
Does TVPaint support 16bit color (HDRI)?
Re: .tif import
Posted: 29 Feb 2012, 15:40
by BenEcosse
it opens a RGB 16bit PSD file ok.
Re: .tif import
Posted: 01 Mar 2012, 08:35
by ematecki
idragosani wrote:Does TVPaint support 16bit color (HDRI)?
Nope, they are converted to 8 bit (taking only the upper 8 bits).
Re: .tif import
Posted: 01 Mar 2012, 08:36
by ematecki
BenEcosse wrote:it opens a RGB 16bit Photoshop file ok. I just convert my image to that. But it's an annoying step to convert it each time so was just wondering what the issue is?
Send us both files (the one that doesn't load and the PS converted one), and we'll see what's wrong and try to fix it.
Re: .tif import
Posted: 01 Mar 2012, 12:22
by BenEcosse
I converted the .tif file to 8bit and it opened into TVP10 ok.
Re: .tif import
Posted: 21 Mar 2012, 10:45
by ematecki
OK, here are the results of the postmortem check :
- tvpaint loads only 16bits PSD files, and converts them to 8 bits.
- thus, tiffs aren't supported in 16 bits.
Re: .tif import
Posted: 23 Mar 2012, 15:33
by BenEcosse
found this
http://www.tvpaint.com/forum/viewtopic.php?f=10&t=5677" onclick="window.open(this.href);return false;
Re: .tif import
Posted: 23 Mar 2012, 16:04
by ematecki
You should use PNG for inter-app transfers.
Re: .tif import
Posted: 23 Mar 2012, 16:30
by BenEcosse
Ok will do that. But isn't PNG a compressed format?
Re: .tif import
Posted: 23 Mar 2012, 16:43
by ematecki
It's a lossless compression, just like when you zip a file, then unzip it, it will be the exact same.
(In fact, png uses the exact same compression algorithm than zip).
Re: .tif import
Posted: 23 Mar 2012, 16:51
by idragosani
PNG was originally intended to replace GIF, and in addition provides better color resolution and gets away from patent issues.
