Coloring after a yellow or blue line is erased?
matthewchapman
Post by matthewchapman »
If I do a sketch on a layer with a yellow or blue line from the custom toolbar (blue pencil toolkit), then press the X to eliminate it, all the lines disappear.
BUT, when I go to color, the lines are still visible to the program (IE using FloodFill).
Am I doing something wrong? The theory with the blue pencil kit is to be able to sketch then eliminate it. Is it that the pressure sensetivity in the tablet makes TVP not key the color perfectly?
Thanks!
Matt
matthewchapman
Re: Coloring after a yellow or blue line is erased?
For example I attached 3 screen grabs
Example 1.JPG (62.5 KiB) Viewed 15405 times
Example 2.JPG (80.63 KiB) Viewed 15405 times
Example 3.JPG (93.38 KiB) Viewed 15405 times
idragosani
Post by idragosani »
What release are you on? I don't see this behavior in TVP 10. Does the same thing happen if you use the eraser for that color?
matthewchapman wrote:If I do a sketch on a layer with a yellow or blue line from the custom toolbar (blue pencil toolkit), then press the X to eliminate it, all the lines disappear.
Thanks!
Matt
Did you ever find a solution for this problem ?
I have tried to duplicate this issue on my end , but it doesn't do this for me. When I hit the "X" in the Sketch Panel to make the color line go away and then use the Fill Tool it works as expected.
Can't reproduce on 9.5.22.
idragosani
Wonder if there is some kind of inverted mask enabled?
Mads Juul
Post by Mads Juul »
In a early version of the Sketch Panel the action wasnt quite right (was it 4 years ago??). it was corrected in later versions. what version of tvp are matthew chapman using? I think a upgrade will solve the problem.
I confirm it's an old bug now fixed.
