tvp crashing
Posted: 24 Apr 2012, 22:19
by dsheahan
Hi -
I just installed the 10.0.6 update to try to fix this, to no avail: When I export a toolbar, tvpaint crashes every time. It happened with 10.0.4 too.
Here's my toolbar export method (simple, really): After renaming it something sensible, I right click and choose Export Toolbar. I have tried renaming it. This has no effect on the crashing.
Some perhaps relevant quirks I've noticed about the export dialog: It provides a default name with either .data or .ini as an extension, while just below it, the option is to Save As Type .bin, which I know from experience is the only type that will open when importing a toolbar. I don't know why it would pick an arbitrary (sometimes long and full of garbagey-looking numbers and letters) name or why .data as the file type, when .bin is what the program uses. But regardless of whether I keep this default name or name it something else, when I Save, tvp crashes.
Thanks for any help,
David
Re: tvp crashing
Posted: 25 Apr 2012, 07:00
dsheahan wrote:the option is to Save As Type .bin
Where do you find this option ? "Save As Type .bin" does not exist in the software.
dsheahan wrote:which I know from experience is the only type that will open when importing a toolbar.
No, .bin was the file format used in TVPaint Animation 8 and Mirage. Now, the common format is ".TVPX", as it contains much more information than a .bin.
I have just tested with a Mac 10.7.3 : no crashes, even if I rename the panel. I used "Export in TVPX" and "Export" : both work well.
What is your OS ? What is your Edition (Standard or Professional) ?
Re: tvp crashing
Posted: 25 Apr 2012, 07:28
by Mads Juul
Elodie wrote:Hello,
It does . If you RMB click a tool bar and choose This Panel>Export
You can still export your custom panel in the old bin format
Re: tvp crashing
Posted: 25 Apr 2012, 07:33
Mads, I didn't say it was not possible to export in .bin.
I said the function's name "Save As Type .bin" does not exist. It is called "Export", simply (look at my previous post :
Elodie wrote: I used "Export in TVPX" and "Export" : both work well.
It is important to use the good terms and good functions' names when having a problem with the software, because misunderstanding can be quick.
That's what I meant by "Save As Type . bin" does not exist". :wink:
Re: tvp crashing
Posted: 25 Apr 2012, 07:43
by Mads Juul
Elodie wrote: It is important to use the good terms and good functions' names when having a problem with the software, because misunderstanding can be quick.
ok. interresting I misunderstood you, and not David ;-)
Re: tvp crashing
Posted: 25 Apr 2012, 07:50
hahaha :mrgreen:
(In fact, I understood too what David said, but sometimes, I'm tired when users don't write the good terms... sorry David :oops:)
Re: tvp crashing
Posted: 25 Apr 2012, 07:55
by Mads Juul
Re: tvp crashing
Posted: 27 Apr 2012, 18:39
by djsolomon
Elodie thank you for the answers - David is working with me and he has not been in since the post ...
Have a lovely weekend!!!
my best djsolomon
