Hi - I recently added a 3rd monitor ( love this set up) BUT the dialog boxes appear on the left hand monitor which is annoying ....as my pen is not mapped to
go to that left hand monitor . Is there any way to have dialog boxes appear( for naming etc ) on the right or middle monitor?
many thanks from Manhattan
dsjolomon
3 monitor set up question
Re: 3 monitor set up question
Yes-- you do this in the nVidia card's settings.
hi Paul - at some point can you tell me which settings? if it s not to much trouble?
thanks debby
thanks debby
While in TVP, look at the very top right corner and you will see an array of tiny icons. LMB on the second one from the left (it's green) and you will get a menu. Look for Individual Setting and select Edit. In the middle of the panel that pops up you should see "Dialogue box control" and select the one that tickles your fancy best.
WARNING: You will have a strong urge to look at other settings. Don't start fooling around with them willy-nilly. Each time you make a selection, check what it does -- if you can't see what it is, set it back to the way you found it and go to the next one.
very thoughtful responce I will not "fool around with the settings"
one million thank yous!!!!
djsolomon
djsolomon
