"Import footage" window is lost
Lukas
Post by Lukas »
I've lost my 'Import footage' window, when I drag a file onto my workspace, the window appears (but I can't see it, it's outside of my screen/workspace/tv-paint-window). I can't do anything anymore, except press 'Enter', which imports it with the wrong settings.
Is there a way to reset the position of the window? It's probably somewhere way up or down, because I've been using dual monitors in weird setups. But I can't find the window so I can't drag it back where I'd want it.
(I'm on TVPaint 9.5.21 on OS X Lion)
Thanks!
Lukas
  • LukasKrepel.nl
  • TVPaint Pro 11.7.5
  • YouTube.com/@ClubBaboo
  • YouTube.com/@FrameOrder
Re: "Import footage" window is lost
hello Lukas,
It should be on the screen : at the very bottom, or on the right/left part of the screen.
it happens seldom, but sometimes only a few pixels are visible
If you cannot find it, reset your config :)
Lukas
Post by Lukas »
It happens when I work with a big TVPaint window, and later am forced to work on a smaller window (less monitors, or a different setup)
How do I reset my configuration? Do I have to backup my own toolbars if I do? I have this problem quite often.
  • LukasKrepel.nl
Yes, you should save all your custom panels, papers etc...
Do you use the Standard or Pro version ?
