Can't set default frame rate when importing PSD
Soom
Post by Soom »
When I import a PSD file into TVPaint, it opens it immediately as TVP project without asking me for project settings. So I cannot even change the default frame rate, which is always 30fps for some reason, but I need it on 24, so every time I open a PSD I need to modify the sequence...
Re: Can't set default frame rate when importing PSD
Hmm, you are right ! There is maybe something to improve here :)
Soom
Post by Soom »
Elodie wrote:Hmm, you are right ! There is maybe something to improve here :)
feature request ! - should i post it?
It's ok, I've just moved the topic :D
