Hi
I want to configure a shortcut or a button to switch between normal timeline to vertical timeline display, The reason why is so I could quickly have a large view of all my layers like photoshop and still have the normal wide timeline available at any time. any ideas how I can do that?
Also why cant I assign Ctrl+M to any thing?
Vertical Timeline? [solved]
Re: Vertical Timeline?
1. Use rooms for it?
2. Probably because it's assigned to something else and first must get unassigned.
Ok using the rooms works well.
About the Ctrl+M, its not on the list, unlike other keys which are assigned and still on the list, this one simply isn't there. but its not a big problem, just wanted to assign Ctrl+M to export after effect style. Shift+M works just the same.
Thanks!
Thanks!
