Page 1 of 2
TVP v10 freezes when 'grab tool'
Posted: 04 Jul 2012, 15:33
by BenEcosse
I keep having an issue when I try and right click on my brushes tool bar and select 'grab current tool' to save my anim brush.
TVP v10.0.5 freezes and I have to abort the programme -this happens every time now.
Re: TVP v10 freezes when 'grab tool'
Posted: 04 Jul 2012, 16:33
by Paul Fierlinger
I have no idea why TVP freezes on you but as a better workaround which will let you actually save your brush, try using the command "add action" and go from there. Does this also freeze TVP on you?
Posted: 05 Jul 2012, 06:53
by Eric Scholl
It doesn't freeze here, can you update your software, please ? Because the last version is the 10.0.7.
Maybe is it only on Windows, because here I am on Linux.
Posted: 05 Jul 2012, 10:51
by BenEcosse
I've updated to 10.0.7 but the issue still persists.
Posted: 05 Jul 2012, 10:57
by Paul Fierlinger
Sorry, I completely overlooked "animbrush", so I just tried it and I didn't get a freeze.
Posted: 05 Jul 2012, 11:22
by BenEcosse
It's only when I use TVP10.
Posted: 05 Jul 2012, 11:29
But Ben, have you updated your TVPaint ?
Posted: 05 Jul 2012, 11:47
by BenEcosse
yes
Posted: 05 Jul 2012, 13:06
by BenEcosse
I took off 'sub pixel' tablet option in preferences and now I can save my the animBrush ok
I found my old post.
viewtopic.php?f=10&t=3091" onclick="window.open(this.href);return false;
Posted: 06 Jul 2012, 04:06
by lemec
This is really strange. The sub pixel option lets you have sub-pixel accuracy from your tablet. This means that line drawing is a lot smoother when using thin brushes while zoomed out. It shouldn't have any effect on the crashing when saving animated custom brushes, but eeh.
Also, I'm using x86 so I probably cannot repro the crash.
Posted: 06 Jul 2012, 15:37
by BenEcosse
ok
Posted: 06 Jul 2012, 18:31
by lemec
Hm. Try these settings. I don't use any of the other options besides Optimize and Display, which I turn on and off as needed if I need to capture multiple layers.
Posted: 06 Jul 2012, 21:26
by BenEcosse
Thanks Lemec.
Posted: 07 Jul 2012, 03:46
by lemec
Hm. when you cut out an animated brush, there's a prompt that says: "Do you want to cut out an Animbrush?" It's often easy to miss this prompt, especially if you're using a dual-display system and the prompt is appearing on a display that you aren't looking at.
Maybe it's freezing because it's waiting for you to hit the OK button.
Posted: 07 Jul 2012, 10:38
by BenEcosse
The issue is something to do with the fact that when I use the right click function on my pen with sub pixel enabled you have to drag the pen at the same time
