Preview : Flip Light Table. Flipping to fast
Mads Juul
Post by Mads Juul »
I just tried the key command Preview : Flip Light Table.
But it is flipping to fast. the images is not displayed long enogh. is there someway to display the images longer.
without changing the preview playback speed.
-Mads
Roselle2
Re: Preview : Flip Light Table. Flipping to fast
Post by Roselle2 »
Hi madjuul,
Flip Light Table.
You must go on Project Window and flip to 6 Frames, no 25 Frames,Ok :wink:
Than, klick Your Key command single, not the key hold. Than Play go verry slowly.
Iff You hold the Key than play gos verry quikly.
g-Roselle2
Mads Juul
Post by Mads Juul »
Hi Rosella
Roselle2 wrote: You must go on Project Window
I guess you mean Remote Panel.
You are right but the problem is that also playback plays by 6 fps.
That means if I should use Preview : flip light table I should
Select 6 fps
flip lighttable
select 25 fps
that is to tedious
And I cant set fps with a shortcut.
what good is a shortcut if I have to do another manual thing before?
I will not use it as it is now(and I have tried the above) so In my opinion when I am working with 25or24 fos wich I always is I think Preview : Flip Light Table. Flipping to fast.
But thankyou for you advice. anyways it is not that important . in the meanwhile I have found Out i can do it with a george script if i want to. Stil If other people is using it. I think it flips to fast. and it is annoying I have to switch fps to make it work.
Roselle2
Post by Roselle2 »
Hi. madsjuul,
yes i think Remote tool . I understand what you do. You want with play lopp are slow (speedlimit ) with Light Tabel Key. From the Layer 25 ore 24 fps.
Yes than get with George. User Roselle2
