Hello again!
I have some drawings on top of each other on separate layers. If I want to move them without merging them into one layer, is it possible to do?
I have tried selecting all the layers then moving, but the transform tool seems to only move one layer at a time. Is there away around this?
I am doing my concept work in TVPaint and need to move things around from time to time, but I don't like flattening in case I want to change something. It is a little bit awkward having to move each layer one by one. Hoping there's a solution I'm not seeing for this :\
Using TVP 9.5.
Thanks!
Move multiple layers with transform tool?
- bleupencil
Re: Move multiple layers with transform tool?
Use the transform tool (Ctrl T), then again and again on every layer. Works fast with a keystroke combo: arrow down, enter, enter - repeat.
- bleupencil
That seems to work really great, thanks!
just to mention it, the alternative in v.10 :
firstly you group the involved layers (setting them under the same color code),
then set your moving (offset/resize/rotation) in the keyframer (a single key),
then Apply FX on Layers Group, Heads only.
- bleupencil
Oh for want of layer groups!
I'll have to wait to upgrade for that I'm afraid. But thanks anyway, stored for future reference
