possible display bug after image import
10.0.11 32bit Mac:
After importing one ore many images, only the left half of the images show up on screen. Only after moving the cursor over the missing areas they show up (chunk by chunk, in blocks of about 128 px). File format of images doesn't matter.
Can somebody confirm this?
Mads Juul
Re: possible display bug after image import
Post by Mads Juul »
I can confirm.
It is the same here. Also Windows 32 bit.
-Mads
Thankf for notifying the bug !
idragosani
Post by idragosani »
Not seeing this issue in 64-bit Linux, TVP Pro 10.0.11... maybe it's a 32-bit issue only?
ematecki
Post by ematecki »
How do you import the image ? By drag'n'drop ? Using "File>Load" ?
Because I can't reproduce it (on my Mac).
I used cmd-O. Will check later with other ways, but have to go now.
Mads Juul
Post by Mads Juul »
Strrange.
I can't reproduced it now. Both with drag and drop or file import. But I had the Display bug yesterday.
OK, I tested again, with the old project file, and a brand new file. It seems to happen only with cmd-O, not with clicking "import" in the "new" layer dialogue.
Image to be imported:
View after importing, right half missing (and a bt on top and bottom as well):
View after moving the cursor, parts appear under the cursor:
The attachment glitch_03.png is no longer available
