Sound not working
Sound not working
I have a problem, that has not happened previously.
When I load the sound into a project, I can see the soundtrack, but no audio.
If I open a mov. or mv4 file, by rightclicking on the file, then choosing "open with TV-paint" then loading in the sound it works,,,BUT when I then modify project to make it the right size, the sound cannot be heard (I can still see the track is there, but no sound) And the same with just making a project, and loading in the sound.
I have never had this problem before, and am just doing the same as always, that usually work.
I have the 9,5 version
Re: Sound not working
Hi Herie,
Welcome to the TVPaint community !
• are you using the last update of TVPaint Animation 9.5 ? (TVPaint 9.5.21)
• what is your computer : Mac, Windows, Linux... ? Which OS ?
Hi Elodie, and thanks
Yes I'm using the 9,5,21
And windows XP
The very strange thing is that it usually works
And windows XP
Whe you resize the project, do you change the FPS value ?
It is also the same when opening an old project, that had sound the last time I had it open.
The track is there, but no sound
Uh don't know what FPS is, so no, I only change the size.
Only way to get sound seems to be when opening a movie file by right clicking + open with TV Paint, and then loading in the sound, but I can choose size that way
Do you have the sound turned off under your project image; the little symbol of a speaker?
I'm trying to find it, can't see it
is it where the sountrack lays?
Thank you thank you
I found it, and it works now
Hurray I'm so happy
Thanks again!!
Hurray I'm so happy
Thanks again!!
You are welcome; this happens once in a blue moon -- the first time ever this happened to someone was I think me.
Oops, sorry, this is the frame rate (how many images / second ^^)Herle Kühl wrote:Uh don't know what FPS is, so no, I only change the size.
• Does the sound enable in your TVPaint ? You should see an icon with a loud speaker in yellow into the remote.
• you don't here the sound when you play or only when you scrub with your mouse / keyboard ?
Edit : Paul was faster ^^
