I've been trying out the oopacity of the penbrush, and I cant figure out how to set the transparent paint without overlays, I can set the opacity by changing percentage and all, but whenever I draw over the spot the lines are visible. Is there a way to make the penbrush opacity stay the same no matter how many times you draw over it with the same brush?
Also important question : How do you set the the penbrush to normal again? The opacity is 100%, but its still transparent, even when I pressed reset... I want that one colour tone back
PenBrush help
Re: PenBrush help
always forger to mention. I have 9.5 version
Re: PenBrush help
lol looks like I found the problems, the power setting was set on pressure and I found the Invert option for the infinite transparency
lock time
lock time
Re: PenBrush help
To be able to step over your last stroke and not have it show, you must uncheck Drying. Turn off paper to turn off transparency.
Re: PenBrush help
Yea, thank you. I had trouble turning those paper tools off. so many tools and options to learn
Re: PenBrush help
But you seem to be good at it.holyax wrote:Yea, thank you. I had trouble turning those paper tools off. so many tools and options to learn
