OUTPUT TOO LONG WITH AUDIO FILE
Posted: 13 Nov 2012, 10:52
by timson
Hi all,
I'm new to TVPAINT and i'm trying to find my way.
I can't get this one solved:
i animated a sequence (200frames) + audio file - the audio file is longer than the sequence
when i export without audio the file is OK, but when I render with audio, the rendered clip is too long, in fact it has been rendered until the end of the audio file (2min ...)
mark in and mark out where correct (200frames)...
anyone has any clue?
Thanks
configuration:
MacOSX 10.7.5 - 64bit - TVPAINT 10.0 (1) PRO
Re: OUTPUT TOO LONG WITH AUDIO FILE
Posted: 13 Nov 2012, 11:12
Have you set the marks in the export panel, or just in the timeline?
Posted: 13 Nov 2012, 11:47
by timson
marks in export panel and in timeline
Posted: 13 Nov 2012, 11:54
by timson
Hi everybody,
The problem only occurs when exporting quicktime, avi works OK.
Posted: 13 Nov 2012, 12:06
Works fine with QT on my machine.
Posted: 15 Nov 2012, 08:17
You are still using the 10.0.1 ? Maybe the update will fix the problem
Posted: 16 Nov 2012, 08:51
by timson
Hi Elodie,
I'm using the 10.0 (1) version.
When I ask for an update, I get this: "There is no new version available."
What should be the latest version?
Posted: 16 Nov 2012, 15:22
by Fabrice
10.0.
11
Posted: 19 Nov 2012, 10:57
by ematecki
timson wrote:When I ask for an update, I get this: "There is no new version available."
That's strange ...
Go there :
http://www.tvpaint.com/v2/content/artic ... pdate.php/" onclick="window.open(this.href);return false;
Enter the informations, and you are sure to get the latest version.
Posted: 21 Nov 2012, 09:47
by timson
Thanks, i've got the latest version
how do i proceed?
do i need to uninstall the previous version?
do i need to take out the dongel and proceed as if i was installing for the first time?
Posted: 21 Nov 2012, 12:07
by ematecki
Just install like the first time, no need to uninstall.
If you are asked to overwrite the old version, just reply 'yes'.
