I would like to apply the "Light Table-effect" on my export file. Is that in any way possible?
So to be more clear: I would like to get the Light Table settings that are visible in the workspace (the preceding and following frames) to be applied on the output video file that I export.
Thanks in advance!
Geugie Hoogeveen
the Netherlands
how to apply light table effect on output file export
Re: how to apply light table effect on output file export
You can simulate this effect by making multiple copies of your animation layer and offsetting each layer by a frame, and finally making each layer a bit transparent in grades.
you can also do it with the fx stack.
put in a keyframer (motion) and set the render tab as follow:
source:Display
offset: 1
opacity: 50 %
then duplicate this keyframer
and only adjust the offset to :2
and opacity to 30%
repeat this as many times you like, all the time adding to offset and reducing opacity
when you are satisfied you can select all frames of the animation and click apply
source:Display
offset: 1
opacity: 50 %
and opacity to 30%
