Questions about Update Function
Posted: 06 Dec 2012, 08:46
before I try it out and fall into some traps, I would like to know something about the update function in TVPaint:
I have TVPaint 10.0.x 64 Bit (NETWORK VERSION !) installed.
I want to make an update using the automatic update function from the help menu of TVPaint. I also like to install parallel the TVPaint 32 Bit version.
1. Using the update function I get an update downloaded. Is this update working for every PC in our network. We have three different dongles.
2. Is there also a possibility to download also the 32 bit version using the update function?
3. If yes and there is no 32 Bit version installed yet, is the update file able to install the 32 Bit version parallel to the 64 Bit version - or do I need a different install version? (I remember the file size of the installer on the cd is much bigger than the update files - that's why I ask.
Many thanks from Animark
