Test with either APenColor or BPenColor selected:
1. Select the Color Picker tab and notice how it works...
2. Press the stylus anywhere in the rectangle modifies only value and saturation but keeps the hue constant.
3. Now move the cursor up, against the white edge, down against the black edge or over to the gray edge and lift your stylus - this sets saturation to zero and sets lightness to 255 or 0 or somewhere in between, supposedly leaving the hue value set wherever it was on the spectrum (green for instance).
4. The bug: Finally, click anywhere inside the rectangle to select a new saturation and lightness. Unfortunately this seems to force the hue value to jump to 0 (red)…
Hue should resume the same value as before shouldn't it?
I understand that with white, black and gray there is no hue, BUT when you re-establish value and saturation again by clicking within the body of the color picker rectangle, it is disconcerting to have hue suddenly appear as bright red, losing whatever the previous hue was.
When I am working with selected hues in the APen and BPen slots, adjusting their value and saturation, and I need white, black or gray, then want to return to previous hues, I would expect to be able to so.
Is this in fact a bug or just an unavoidable consequence of the way hue, value and lightness is calculated in the picker panel?
A BUG: in the Color Picker Tab of the Palette Panel? Topic is solved
Re: [FIXED!]A BUG: in Color Picker Tab of Palette Panel
Tests in TVPaint 10.5.2, for this previously reported "BUG" in the color picker tab AND with the color sliders tab, reported elsewhere... seems to have been completely, spectacularly FIXED! Congratulations to the coder who resolved this one.
Now, the hue is stable and remains totally recoverable after setting Saturation to zero (no more defaulting back to hue 0 - red when re-establishing higher saturation levels) - it now lets you re-introduce saturation with your original hue setting still intact.
Thanks for that.
Thanks for that.
Re: [FIXED!]A BUG: in the Color Picker Tab of the Palette Pa
+1!
Wow, these are good news - and I am thinking about leaving 10.0.14 ... maybe next week, when there is more time.
TVPaint 10.5.7 - Win10/64
TVPaint 11.0.8 - Win10/64
