Why are the imported images upside down?
Ami
Post by Ami »
Hi!
I'm back using Tvpaint after a long break, and here's the question: I am importing image sequences but they appear upside down?
Any ideas why?
Ami
-- mac 10.6.8.
--tvpaint 9.5.21
Ami
Re: Why are the imported images upside down?
Post by Ami »
Or actually they are mirrored/flipped!
Ami
Eric Scholl
Post by Eric Scholl »
Are they already mirrored in the import panel ?
Go to "View" and see if "Flip Horizontally" or "Flip Vertically" are checked and uncheck them.
Ami
Post by Ami »
Yes they were already mirrored in the startup panel.
I imported them and then i flipped horisontally to get it look right. but when I render them out, it's again mirrored. so what to do?
Could you show me an image with the result you want and the result you obtain ?
ematecki
Post by ematecki »
What format are your images in ?
JPEGs from a camera ?
Ami
Post by Ami »
Scanned images..
Ami
Post by Ami »
Tiff. Hp scaner. I didn't have the problem with epson scanner. can that be it?
Could you show us an image with the result you want and the result you obtain ?
ematecki
Post by ematecki »
Ami wrote:Tiff. Hp scaner. I didn't have the problem with epson scanner. can that be it?
I think your scanner driver/software sets the rotation flags in the tiff file instead of really rotating the image.
Can you try with PNGs (if your software allows it) ?
